Electrical quits for no reason
Old 02-02-2016, 01:22 AM
koyote's Avatar
Question Electrical quits for no reason
HELP! My great little '98 CRV has a perplexing problem. The electrical system fails intermittently for no reason, stalling the vehicle. So far it has failed approx. 9 times and it has only failed on occasion when I slow down and take my foot off the accelerator at a stop sign or intersection. I have to push it to side of road and after about 2 to 5 minutes, electrical comes back on and I can restart the car. The battery and it's connections, the starter and alternator all have been checked and they are good. I can't continue to drive it for fear that it will fail in heavy traffic at night and I will be left with no headlights, leaving me in danger. It will drive fine for a day to a week or two with no problem. Then it will fail again. Has anyone had a similar problem? What could be the cause? My repairman can't figure it out.
Old 02-03-2016, 05:25 AM
welcome to the forum. I ran into this with another make car, and found at th fire wall the electrical connection ( many wires cannon plug ) to be loose, it only happened at various times, and the dealer was surprised to see this. on the firewall engine compartment side. this may be difficult to find on the crv.
Old 02-04-2016, 12:21 PM
koyote's Avatar
Default Thanks Acmech52 . . .
I shared your info with my repairman. He said he would check that. He also found that the ignition and starter were defective. He will check the connection you speak of as well. Thanks.
Old 02-06-2016, 05:57 AM
note: if you have a key chain with lots of keys or junks, this can damage the ignition switch area. only have a key and alarm sys on the key chain. keep your other keys on another ring.
Old 02-06-2016, 08:49 PM
koyote's Avatar
I only had the ignition key and the remote device for opening the doors on key ring. The repairman said it was the original ignition and was worn. I have been driving it again for two days and so far no stalls so I hope that was the answer.
I knew the school teacher I bought the CRV from four years ago. She was a heavy purse sort of person, so quite possibly she was also a heavy key ring sort of person.
I'm glad to have my car back home.
Old 02-07-2016, 06:16 AM
good to know.
Old 02-11-2016, 06:24 PM
I have heard of that with some GM cars.
heck
07-05-2009 12:13 PM
jsw1208
09-27-2006 08:13 PM
artist118
08-29-2006 12:31 PM
Fire
07-22-2006 07:26 PM
klholder
06-30-2006 11:33 AM
Quick Reply: Electrical quits for no reason
