1997 CRV oil level
Old 08-23-2015, 01:38 PM
anon125's Avatar
Default 1997 CRV oil level
the dealer changes the oil.
the dipstick has 2 holes. the top one is supposed to be the max.
whenever we check it, the oils is always over that amount.
we check in the morning before use.
are they putting in too much oil?
thanks
Old 08-26-2015, 02:37 AM
no, when honda does your oil change, they put in enough oil to compensate for the oil filter, run the engine and then recheck the oil level. If you run your engine first, then check your oil, it should be at the top hole.
Old 08-26-2015, 09:52 AM
anon125's Avatar
Thanks, so weeks later if we check it in the morning where should the level be?
Old 08-27-2015, 03:06 AM
after a short run and providing the engine is not burning oil, it should be at the top hole. (Just for info, My o7 Fit from the time I purchased it, at 60% oil life, i add a quart, at 30% oil life I add a quart of oil. currently it has 250k miles and runs good.)
Old 08-27-2015, 11:23 AM
anon125's Avatar
we have never added oil to our 97 Honda in 17 years. it is low mileage.
the oil is always beyond the top hole.
thanks
Old 09-08-2015, 09:58 PM
lowlife9's Avatar
thanks
jesus you never changed the oil in 17 years ???
Old 09-09-2015, 12:31 PM
anon125's Avatar
correct.
what I wrote was I never added oil.
the dealer did the oil changes
anon125
10-17-2015 12:09 PM
leep
06-11-2013 10:02 AM
Frodo_DLB
10-06-2009 02:29 PM
shad9876
09-03-2008 12:57 PM
Quick Reply: 1997 CRV oil level
