antifreeze leak
Old 09-09-2016, 11:44 AM
Haydad's Avatar
Default antifreeze leak
Honda LX 4S: New to Honda's, My granddaughter"s Honda has an antifreeze Leak coming from a device that sits on the top, middle, back of the engine. Any idea what can be or needs to be done to stop this leak.
If more info is need will be glad to provide what I can.
Thanks in advance!
Old 09-10-2016, 05:27 PM
lowlife9's Avatar
are you talking about the iacv or idle air control valve ??? coolant does run to the iacv, you can remove clean and replace the seals. also make sure the lines aren't damaged and are clamped off properly. there are many DIY videos on youtube.
Old 09-11-2016, 03:08 PM
Haydad's Avatar
Thanks for the reply. Don't know if it is the iacv but here is a picture
Old 09-11-2016, 03:13 PM
Haydad's Avatar
Default Antifreeze leak
Thank you for the reply. I don't know this car that well to tell you what the name of the part might be. Hope the picture helps.
99accordcoupe
11-03-2009 08:47 AM
zacary
02-15-2008 05:28 PM
XHONDAX
09-17-2006 09:31 PM
unclewilco
08-15-2006 08:40 PM
slantill
06-26-2006 02:47 PM
Quick Reply: antifreeze leak
