Sponsored by:
Sponsored by:
Drivers window doesn't work
Old 08-26-2015, 09:31 AM
Coolsmt6's Avatar
Default Drivers window doesn't work
The drivers window only works like once a month for a min or two then stops working till another month. All the other windows roll up and down no problem. Can someone tell me if they've had this issue and what it could be to help diagnose he real problem. Thanks
Old 08-27-2015, 03:09 AM
welcome to the forum. Could be the motor bad contact or defective.
Old 10-21-2015, 12:22 PM
wagonguy's Avatar
Clean the connectors on the harness. See if it helps.
If not then take your window switch apart and check / clean the contacts in it
good luck!
Old 10-24-2015, 06:46 PM
Welcome in sounds like a loose connection or short in the switch.
tneilscott
06-10-2015 12:31 AM
Raven
11-05-2012 08:07 AM
misterix
07-11-2009 05:29 AM
hotpeds
05-03-2009 10:00 PM
VTECwarrior
04-11-2009 12:56 AM
Quick Reply: Drivers window doesn't work
