Oll filter location in 8hp 4stroke 2015
Old 06-21-2016, 05:12 PM
ChimeraKC's Avatar
Default Oll filter location in 8hp 4stroke 2015
Trying to change the oil filter and the manual says to remove the six bolts and remove the R engine under cover. Assuming R means right, if thats the side that the oil dipstick and oil filler tube is, then that means looking at the motor from the back?
Anyway, in addition to the screws, and I only counted 5, there are two plastic fittings coming through the cover - hmmm. I wedged them out and they are very solidly connected to hoses going into the motor. So are you supposed to just get them out a bit and then hold the cover in your hand while you replace the filter?
I couldnt imagine that, and I am on a ladder - sailboat is on a high trailer - so I removed the under cover on the other side and the filter is not there.
Any suggestions? Thanks
smartbel
05-08-2015 07:02 PM
Marc
05-21-2012 04:18 PM
mike0094
02-18-2009 12:12 PM
brandon81
03-19-2007 05:58 AM
1998HondaCivic
01-20-2006 02:13 AM
Quick Reply: Oll filter location in 8hp 4stroke 2015
