Other Honda Cars and Trucks Don't see your vehicle listed above yet? This is the place for your information.
2001 Honda passport
Old 02-27-2017, 07:55 PM
Carson Logwood's Avatar
Default 2001 Honda passport
So my passport recently ran out of gas and sat for 2 months before I finally got around to working on it, I got it to start by turning the motor over and holding the gas a little bit but once I shut it off, it won't start back up until a few hours later. While it runs the idle is high like a car usually does during a cold start but after it warms up the idle drops and drops all the way down to 300 rpm and then it shuts off, I've replaced the fuel filter and ran a fuel pressure test which measured 40psi with KOEO (Key on engine off) and while it ran it measured 40 psi but once the rpm dropped below 800, the gauge needle started to shake with the rest of the car and it dies.
Old 03-01-2017, 03:53 AM
check/clean the ICO.
Old 03-01-2017, 10:43 AM
I don't know what you mean by "ICO"
Old 03-02-2017, 03:52 AM
Idle cut off. will cause idle to go high on cold start, to start and die, or low idle below 800rpm. if you have over 100k miles sometimes a valve adjustment will cause the same.
Carson Logwood
01-24-2017 04:13 PM
Carson Logwood
01-16-2017 09:02 AM
Carnage_7
05-09-2008 03:46 PM
atikovi
11-07-2006 09:26 AM
jack_spicer
08-18-2006 12:46 PM
Quick Reply: 2001 Honda passport
