2001 Honda passport - The unofficial Honda Forum and Discussion Board Forums For Honda automobile and motorcycle enthusiasts.
Thread Tools Search this Thread
Old 02-27-2017, 07:55 PM
Default 2001 Honda passport
So my passport recently ran out of gas and sat for 2 months before I finally got around to working on it, I got it to start by turning the motor over and holding the gas a little bit but once I shut it off, it won't start back up until a few hours later. While it runs the idle is high like a car usually does during a cold start but after it warms up the idle drops and drops all the way down to 300 rpm and then it shuts off, I've replaced the fuel filter and ran a fuel pressure test which measured 40psi with KOEO (Key on engine off) and while it ran it measured 40 psi but once the rpm dropped below 800, the gauge needle started to shake with the rest of the car and it dies.
Old 03-01-2017, 03:53 AM
check/clean the ICO.
Old 03-01-2017, 10:43 AM
Quote:
I don't know what you mean by "ICO"
Old 03-02-2017, 03:52 AM
Idle cut off. will cause idle to go high on cold start, to start and die, or low idle below 800rpm. if you have over 100k miles sometimes a valve adjustment will cause the same.
Thread Thread Starter Forum Replies Last Post
2001 Honda passport gas gauge does not work Carson Logwood Other Honda Cars and Trucks 0 01-24-2017 04:13 PM
2001 Honda passport timing belt broken Carson Logwood Other Honda Cars and Trucks 2 01-16-2017 09:02 AM
1997 Honda Passport Carnage_7 Other Honda Cars and Trucks 0 05-09-2008 03:46 PM
2001 Passport EX 4x4 for sale atikovi PRIVATE For Sale / Trade Classifieds 0 11-07-2006 09:26 AM
1994 honda passport turn signals not working jack_spicer General Tech Help 1 08-18-2006 12:46 PM
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
