Go Back   The unofficial Honda Forum and Discussion Board Forums For Honda automobile and motorcycle enthusiasts. > Honda Automobiles > Ridgeline Forum
Sign in using an external account
Register Forgot Password?
Search
Thread Tools Search this Thread
Old 10-04-2011, 10:42 AM
stook00 stook00 is offline
Default D.I.Y- Replacing the Radiator on a '06 Ridgeline
Hi folks,
I haven't posted on the Ridgeline section in a while so I've decided to share a succinct write-up on replacing the radiator on a '06 model with you guys. Enjoy!
1) Make sure the anti-theft codes for the audio system and navigation system (if equipped) are available.
2) Disconnect the negative battery cable.
3) Drain the engine cooling system.
4) Remove the two retainers and front air intake duct.
5) Remove the retainers and the front bulkhead cover.
6) Disconnect the fan motor connectors (A), then remove the harness clamps (B) and reservoir tank hose (C).
Click the image to open in full size.
**Fan motor connectors (A), Harness clamps (B) and Reservoir tank hose (C).**
7) Disconnect the upper and lower radiator hoses.
8) Unfasten the retainers, then remove the splash shield.
9) Remove the automatic transmission fluid (ATF) cooler hoses from the radiator, then plug the line and hose.
10) Unclamp the ATF cooler hoses clamp on the ATF cooler line.
11) Remove the harness clamps (A) and A/C compressor clutch connector (B) from the A/C condenser fan shroud.
**Harness clamps (A) and A/C compressor clutch connector (B)**
12) Remove the upper bracket cushions, then pull up the radiator.
13) Remove the fan shroud assemblies and other parts from the radiator.
14) Install the radiator in the reverse order of removal. Make sure the upper and lower cushions are set securely.
15) Fill the radiator with engine coolant, then bleed air from the cooling system.
*diagram courtesy of hondapartsnow.com; all rights reserved
This ad is not displayed to registered members.
Register your free account today and become a member on HondaForum!
__________________
If it ain't broken then break it!
Old 08-22-2012, 12:53 PM
bucwheat bucwheat is offline
Good find.
__________________
Casper is a 2012 Corvette Grand Sport w/ Heritage package.
Tags
06, coolant, diy, forum, forums, honda, motocross, plastic, powered, radiator, removing, replacing, ridgeline, shrouds, sponsorship, vbulletin
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for HondaForum.com content, comments, or advertising. HondaForum.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse HondaForum.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
