Replace 17" Rims w/16" rims
Old 02-23-2014, 11:48 AM
NBill's Avatar
Default Replace 17" Rims w/16" rims
I have snow tires that are on the rims. I had them on my 2004 Intrepid. I just bought my 2008 CRV and would like to use them. The sizes are 225/60/16 snow tires on rims and the ones on my CRV are 235/65/17. Is this possible? I realize it will affect the speedometer a little.
Old 02-24-2014, 07:55 AM
as long as the bolt pattern is the same then you should be fine also if the rim clears your brakes or suspension being a smaller rim it mite interfere with those parts.
Old 02-24-2014, 06:29 PM
Easiest way to find out is mount one.
Old 05-05-2014, 01:55 PM
caddy1029's Avatar
First and foremost, there's not a great chance that the bolt pattern will match. Secondly, you are downgrading in two out of the three dimensions, so you are going to look like you stole your wheels off a Power Wheels. The correct size ratio to move from a 17" rim to a 16" would be a tire size of 215/70r16. (As a side note, your tire size is most likely 225/65r17, not 235/65/r17.) If your vehicle is AWD, then not only will your spedo be negatively affected by the wrong tires, it'll also screw up your differential and transmission too.
wesley123
06-07-2010 11:47 AM
dinz334
05-17-2010 05:28 PM
marwataymour
02-10-2010 04:39 AM
djletin
05-24-2009 08:58 PM
wheelguyz
08-11-2006 06:04 PM
Quick Reply: Replace 17" Rims w/16" rims
