Fit Forum This sporty new sub-compact combines the efficiency of a economy car with the interior room of some minivans.
How to Remove and Reinstall the Centre Console on a '07 Fit
Old Sep 22, 2011 | 11:18 AM
stook00's Avatar
Default How to Remove and Reinstall the Centre Console on a '07 Fit
What's going on guys,
My brother asked me to help him remove the centre console on his Fit so that he can replace it with a carbon fibre unit. While it didn't suit my personal taste, I fulfilled my fraternal duties and happily obliged
Here's the procedure for removing and installing the centre console on a '07 Fit:
1) Remove the parking brake cover lid.
2) On M/T models, remove the shift **** by unscrewing it.
3) Remove the center console (A) by removing the screws (B), and clips (C).
4) Lift the rear of the console up to detach the clip (D), and pull the console rearward to release the front hook (E) from the heater unit.
5) Disconnect the accessory socket connector (F), and if equipped, auxiliary jack connector (G).
**Centre console removal**
To install:
1) Install the console in the reverse order of removal, and note these items:
  • Check if the clips are damaged or stress-whitened, and if necessary, replace them with new ones.
  • Make sure the wire harness is not pinched.
  • Make sure each connector is plugged in properly.
  • Set the rib (H) under the pocket onto the parking brake lever bracket (I) correctly.
**console diagram courtesy of hondapartsnow.com
Old Jan 27, 2012 | 02:42 PM
Good write up sir.
bucwheat
May 4, 2009 08:17 AM
mike0094
Mar 9, 2009 12:07 AM
miguerh
May 18, 2008 01:47 AM
malvin
Feb 4, 2007 06:49 PM
SGF
Nov 25, 2006 01:38 PM
