Fit Forum This sporty new sub-compact combines the efficiency of a economy car with the interior room of some minivans.
Rough Idle cold
Old Aug 10, 2012 | 03:56 AM
Default Rough Idle cold
update on my 07 Fit. cold starts idle rough, if a/c put on, engine dies or if placed in gear, engine dies after a few seconds. Replaced spark plugs, bleed air from idle side of throttle assy, cleaned throttle body with cleaner, no spray. Finally took it to the shop and had the valves adjusted. Found out that due to the valves being a bit on the tight side, there was insufficient vaccum going to the sensors causing the engine to die only cold and blue engine cold light on. After adjustment, engine smooth and never dies cold or warm. Back to original. milage now 185k.
Old Dec 12, 2012 | 05:25 PM
I would never have guessed that Doug,glad you have the problem solved. Good for another 185k
abiliojr
Jul 11, 2009 03:31 AM
cravnspd
Nov 20, 2008 12:47 PM
mharris251
Sep 3, 2008 11:48 PM
StevieD03
Jun 13, 2008 02:04 PM
hondafied
Mar 17, 2007 01:49 PM
