Wheels and Tires All wheel and tire discussion
Front wheel tight
Old Aug 28, 2012 | 07:55 PM
james nibbles's Avatar
Default Front wheel tight
Noticed a rubbing/grinding noise when turning sharply coming from drivers side front. I jacked it up and removed the wheel to check rotors/cv joint but noticed the wheel would barely turn. I removed the calliper and pads completely but the rotor and hub still only turn with a lot of force. Car is in neutral, can't see it rubbing anywhere...? Wheel bearing possibly?
2005 Accord EX-L
Any help appreciated,
Thanks
Old Aug 28, 2012 | 08:36 PM
Took the passenger side front off for comparison and it was also tight....fyi.
Old Aug 28, 2012 | 11:09 PM
if it makes noise only when turning then CV.
Old Aug 31, 2012 | 09:35 AM
Check your wheel bearings maybe.
Old Jan 14, 2014 | 02:38 PM
charlessmith's Avatar
Arrow
Yes , changed both inner and outer bearings , changed teflon spacers around , changed hex and pin.
Tried both a pro-line wheel and stock wheel with same result.
I just got the truck a couple weeks ago and ran it a few times , dont know if the wheel was tight then or not? Never looked at it untill today. I installed a new set of pro-line wheels and found it tight , thought maybe the wheels were the problem and put the stocks back on but it was still tight.
Thats when I started changing all the new parts.
yrk
Oct 15, 2009 11:59 PM
bhonda69
Jul 21, 2009 08:07 PM
rm49
Jan 12, 2009 09:05 AM
suzy fisher
Dec 1, 2008 12:45 AM
SOKal
Nov 23, 2006 01:27 AM
