01 Odyssey Question
Old Mar 11, 2013 | 10:48 AM
iMatthew's Avatar
Default 01 Odyssey Question
I bought the following stereo from BestBuy and installed it successfully. However, I'm not sure which wire from the car I need to connect to my harness in order to send the signal from the remote on the steering while into the stereo I recently installed.
Amazon Amazon
If anything is unclear, please tell me, I'd be happy to tell you so I can resolve this issue.
Thanks
Old Mar 11, 2013 | 01:44 PM
did you look on the bottom of the radio ??? http://www.amazon.com/gp/customer-me...&totalImages=5
Old Mar 11, 2013 | 02:46 PM
iMatthew's Avatar
Yes, I know that side. I'm sorry for being unclear, my question isn't about this radio. I'm wondering which wire that one needs to connect to in my odyssey, because the colors of the wires on my new radio and harness aren't the same as the factory ones.
Old Mar 11, 2013 | 09:18 PM
did you purchase a separate wiring harness specifically for your car or are you using the harness that came with the stereo because the ones made for your car should be color matched nor need splicing at all it should be plug and play. you can also search the internet for wiring schematics or contact a honda dealer.
Old Mar 12, 2013 | 05:58 AM
iMatthew's Avatar
Yes, i bought the harness for honda vehicles at best buy. Ill look into the schematics. If you find a good one, id appreciate a link.
Thanks for the help
Old Mar 12, 2013 | 02:06 PM
i searched a little for some wiring diagrams to no avail but i know for a fact there out there.
Old Mar 12, 2013 | 02:56 PM
iMatthew's Avatar
i sure hope so, if you find anything please be sure to show me. Thank you again for your time and help
Old Mar 14, 2013 | 11:32 AM
You might check with places that install custom radios,they may be able to help,I'm sure they have run into this problem.
Old May 19, 2013 | 12:26 PM
Acrdr's Avatar
You need to buy a separate harness that only controls the steering buttons with aftermarket radio
Old May 20, 2013 | 05:49 AM
  #10
iMatthew's Avatar
A link would be appreciated, also that doesnt seem to make sense as i could just use the exisisting wires on my current harness that are intended for steering wheel control
