Window Power Issues
Old Mar 21, 2013 | 04:25 PM
aaronj's Avatar
Default Window Power Issues
So I've got this weird problem that all of the windows won't roll down except for the driver side, odd. When I push the buttons to roll them down I hear the particular door where the window is make a click noise but nothing happens. I know its an electrical issue just not sure whether I can fix it myself or not. Any help would be great, thanks!
Old Mar 21, 2013 | 11:35 PM
could be the switches or even the motors. your going to have to narrow it down.
Old Mar 22, 2013 | 07:27 AM
aaronj's Avatar
at first I thought it was the motor just because when i hear that "click" when i try to use the buttons i assumed the windows were getting power but thats as far as it was going. Thanks for responding
Old Mar 24, 2013 | 05:33 PM
check the wires on the motors with a multi meter and see if there getting power.
Old Mar 26, 2013 | 01:56 PM
Is the lockout button activated?
Old Mar 27, 2013 | 07:30 AM
aaronj's Avatar
haha no its not, if the lock out button is activated then I don't here the "clicking" noise where it sounds like the windows is attempting to work, obviously if it is not activated then I hear that "clicking" noise.
Old Mar 27, 2013 | 07:45 AM
So do the other switches on the remaining doors work? As lowlife said check for power to each switch.It is most likely the main switch that is causing the problem,I had one that would not go up/down and it turned out to be a bad ground.
Old Mar 28, 2013 | 07:31 AM
aaronj's Avatar
ya the switches on each door do not work. Even on the driver door, if i try to roll down the other windows those don't work either. Only the driver window will roll up/down. Ground is a good idea thanks.
Old Mar 28, 2013 | 11:39 AM
Let us know what you find out.
lciambotti
May 31, 2014 03:13 PM
93accord
Aug 3, 2009 12:07 AM
nelpasa
Mar 9, 2007 11:02 PM
han_doi
Nov 18, 2006 02:52 AM
jsachen
Jun 10, 2006 01:39 PM
