IAC? HELP!! 98 Accord!!
Old Apr 27, 2013 | 05:03 PM
bendro70's Avatar
Default IAC? HELP!! 98 Accord!!
When car is cold, it idles ok as soon as it warms up just a little....rough...stall. I cleaned the IAC,still the same. The car will at least idle when I unplug the IAC, it surges but at least it doesn't shut off. NO CODES are coming up!!!??? 98 Accord 2.3 VTEC
Old Apr 28, 2013 | 12:23 PM
have you tried cleaning your egr valve. allows engine to surge when warm.
Old Apr 29, 2013 | 09:28 AM
Also you might want to check the TPS, O2, and Timing.
Old Apr 29, 2013 | 02:39 PM
bendro70's Avatar
ACMECH52, The EGR was the culprit, it was stuck open and causing misfire codes. Thank you!!
Old Apr 30, 2013 | 08:40 AM
Nice going Doug!
elang
Aug 24, 2019 01:44 PM
stryker24
Jul 20, 2011 05:35 AM
zanderd
Apr 29, 2010 03:11 PM
