Help with 2000 Accord EX Front Hub Removal
Old May 1, 2013 | 10:43 AM
robertc0087's Avatar
Default Help with 2000 Accord EX Front Hub Removal
I need to replace the bearings on the front drivers side of my 2000 Honda Accord EX. I have been able to find "Accord 98-2002" videos and walkthroughs but the 2000 seems to be a different setup. I understand it's easier to just get the hub assembly instead of trying to remove the bearings, which is what I did with the rear when it needed to be replaced. The rear came off pretty simply after some elbow grease, but I'm having difficulty removing the front assembly. The wheel has been removed, caliper is off, rotor is off, spindle nut has been removed, but the assembly doesn't want to budge. We aren't able to see any bolts on the back side even after taking the dust cover off but it's possible we may have missed something, otherwise it's just REALLY on there. I was just hoping someone could confirm whether or not there's anything else we need to do to remove the assembly before we get too rough with it. Any help would be appreciated!
Old May 3, 2013 | 10:27 AM
Welcome in,try some PB Blaster or any penatrating fluid ,let it soak and try that ,especially if you drive up North, the rust can effect it.Then try a hammer to loosen it.
deezbs
Sep 7, 2012 08:18 AM
suzy fisher
Dec 1, 2008 06:28 PM
Suze
Oct 17, 2007 02:24 PM
davidLX
Nov 30, 2006 06:11 PM
JJ98
Sep 15, 2006 11:24 AM
