02 crv condenser fan runs constantly
My cooling fan doesn’t work (jumped with power on pigtail) so I think it is bad but my condensing fan runs all the time if I hook up temp switch on radiator. If I unplug the temp switch it operates correctly, coming on only with the a/c. Do I have another problem with that fan or is the temp switch bad or is there cross wiring somewhere?
Originally Posted by Mcfam
(Post 43555)
Which ground?
temp switch, condenser fan, or cooling fan? |
You want to test the fan motor you need power and GROUND to test.
I was jumping with a hot and ground from battery, sorry about the miscommunication. Any ideas on the condenser fan running constant ( turns on as soon as I turn the key on) when the temperature switch is plugged in?
(Post 43560)
The AC fan may have a stuck relay. If you applied power and ground to the other fan and it did nothing the fan motor has open windings and needs to be replaced.
Swapped relays no change, but if I unplug the temperature sensor on the radiator it comes on and off with the a:c switch. Do I replace the sensor or is there something else wrong in the wiring?
(Post 43568)
Download the service information. Link is provided by
https://www.crvownersclub.com/thread...ersion.217090/ |
