'08 CR-V Fog Light Bulbs
Does anyone out there in Honda land know how to properly change the factory Honda Accessory Fog Light bulbs? I have removed the splash pan under the front end and it still takes a Houdini to get at them. Must be made for little hands, certainly not mine.
Try this.
1. Passenger’s side
Remove the three holding clips with a flat-tip screwdriver.
Pull down the under cover from the bumper carefully.
2. Remove the electrical connector from the bulb by pushing on the tab to unlock it, then slide the connector off the bulb.
3. Remove the bulb by turning it about one-quarter turn counterclockwise.
4. Driver’s side
To change the bulb, start the engine, turn the steering wheel all the way to the right, then turn off the engine.
5. Use a flat-tip screwdriver to remove the two holding clips from the inner fender, and pull the inner fender cover back.
6. Remove the electrical connector from the bulb by pushing on the tab and pulling the connector down.
7. Remove the bulb from the fog light assembly by turning it onequarter turn counterclockwise.
8. Insert the new bulb into the hole, and turn it one-quarter turn clockwise to lock it in place.
9. Push the electrical connector back onto the bulb. Make sure it is on all the way.
10. Turn on the fog lights to test the new bulb.
11. Passenger’s side
Reinstall the under cover and put the holding clips back in place.
Driver’s side
Reinstall the inner fender. Make sure it is installed under the edge of the front bumper.
Reinstall the holding clips, and push in the head of each cl
1. Passenger’s side
4. Driver’s side
Driver’s side
