1996 CRV JDM CEL and ABS codes
Hello, this is my first post but Ive been a forum lurker for some time. I finally have a problem I cant seem to figure out. I have a JDM model 1996 Honda CRV complete with the useless nav system and everything. I purchased her about 6 months ago. first thing I did was change the oil, transmission fluid and brake pads. The transmission fluid was very dirty but did not smell burnt. Has been running better ever since. Today I got a CEL light and yesterday i got an ABS light that went away. I jumped the OBD1 port and got the following codes:
CEL 03 ABS 5 short, 7 short, 5 long 1 short? The CEL code 03 is for the MAP sensor, I will try to unplug and replug that one in. The ABS codes I am having trouble reading. I took a video if anyone can help me count. I have been using this thread as a guide: ECU AND ABS CODES HERE! - Honda-Tech 94-97 ABS CODES (thanks to JimBlake): You pull these codes the same way you pull check-engine codes, but it's the ABS light that's blinking. Here's the sequence... Insert the jumper, then turn on the key. Long (2sec.) flash - long (2sec.) pause - this isn't the code yet. Short flashes for the first digit of the code - 1sec. pause - short flashes for the 2nd digit. Long (5-second) pause, then the next code. (94-97) ABS DTCs... 1 - ABS pump motor over-run 1 2 ABS pump motor 1 3 high pressure leakage 1 4 pressure switch 1 8 high pressure system 2 1 parking brake 3 1 pulser RF 3 2 pulser LF 3 4 pulser RR 3 8 pulser LR 3 12 different diameter tires 4 1 wheel sensor RF 4 2 wheel sensor LF 4 4 wheel sensor RR 4 8 wheel sensor LR 5 - rear wheel lock - R/L 5 4 rear wheel lock - R 5 8 rear wheel lock - L 6 - fail-safe relay - F/R 6 1 fail-safe relay - F 6 4 fail-safe relay - R 7 1 solenoid - RF 7 2 solenoid - LF 7 4 solenoid - R 8 1 ABS function 8 2 CPU comparison 8 4 IC self-check There's NO long flashes, it's all short flashes with short & long pauses in between. That ABS code guide states that there are only short flashes but I clearly see long flashes for what looks like the 3rd code. Maybe JDM is different? |
