1998 honda crv
Old Oct 22, 2011 | 06:22 PM
bowhunterparamedic21's Avatar
Question 1998 honda crv
I have a 98 crv. It is having major problems starting. I have replaced the fuel pump twice, checked for leaks in the line, replaced the coolant temperature sensor and starter. Once it starts it runs fine. Even if its turned off for 10 minutes it is hard to start. Is there a pump regulator or a vacuum regulator? Any advice on what to check next?
Old Oct 23, 2011 | 09:26 PM
welcome to the forum. do a compression check to see if you have low compression. are your spark plugs and wires in good condition. when did you last tune up the crv. check you ignition coil, it may have burn marks or overheated discoloring.
Old Oct 25, 2011 | 02:30 PM
There is a fuel pressure regulator and fuel pump relay.I would check those next.
Old Nov 21, 2011 | 09:53 AM
Derek_Miller's Avatar
and i read somewhere that the weather could affect it too...if its too cold the engine wont start well cuz the oil becomes thick and the battery becomes ineffective. Whats the weather like where you live?
Old Dec 12, 2011 | 09:17 AM
Are you talking about a Diesel Derek?
Old Aug 19, 2020 | 01:30 PM
kg4mck's Avatar
Default 98 honda cr-v hard start
I have this same problem changed fuel pump, fuel filter, fuel pressure regulater doesnt show a sign of being bad.
Old Aug 19, 2020 | 05:46 PM
Hoping this is a gas engine??
Check fuel pressure when first turning the key to the ON position
Or listen for the fuel pump to prime the fuel rail
Then check to see if there is fuel pressure at the rail by loosening one of the connections
How much wants to come out would indicate high, low, or no pressure
Check for spark, check to see if the spark plugs are fouled
Check power and grounds to the coils
Chris Pickett
May 31, 2023 02:45 PM
stumped
Jul 29, 2007 08:36 PM
silverbullet
Jan 22, 2007 02:21 AM
inline4
Sep 20, 2006 08:06 PM
hondaex
May 19, 2006 01:12 AM
