2004 crv driver's lock?
Is your door open while u are trying to do this. Is there a door ajar light on the dash? U will not be able to push the lock pin on driver door down with the door open (if door is open you must pull drivers door handle (inside car) and hold the handle out while pushing the lock pin down) I dont beleive the door lock actuator would cause this as it will still function properly when using the fob or pass side door to lock it.. If im understanding correctly.. If the actuator was the cause it would only lock when using the key or pushing the pin down inside the car. (Fob wouldnt lock it ...power lock buttons inside both doors would not lock it.
I just bought a 2005 Honda CRV 2 days ago with the exact same prob
