2007 2.2 CRV hesitating.
Hi Everyone. I have a 2007 2.2 ICDTI CRV and when cruising along any road, if my foot is barely on the accelerator, the car seems to hesitate/"stutter". When i press accelerator harder, it goes away. Car takes long to pick up speed to overtake.
I've researched a lot of sources and it seems it is most probably the TPS (throttle position sensor). Here's the problem : i cannot find a TPS anywhere in south africa, and Honda dealership says it cannot be bought separate, but is part of the the Valve assembly (throttle body) at a price of R9000. Anyone any advice on places i can shop at, or anything else? Maybe it is NOT the TPS? |
Have you tried cleaning the throttle body and IACV??
Originally Posted by avisitor
(Post 43131)
What is the IACV? |
You need to put a good scan tool on it and see what's going on. Could be simple or could be you need a new throttle body. The dealer just shoots from the hip and hopes to hit the moon.
Ai ya yai!! A new throttle body is more than half my salary!!!!! 😱 Im looking for used part for now.
But it seems to be the way to go. Will put an update here when i have news |
Originally Posted by CRV-lover
(Post 43135)
(Post 43132)
I cleaned the throttle body with special Sensor cleaning spray, didnt take it off to clean, on-car clean only.
What is the IACV? Does your engine runs on diesel? Could be low fuel pressure? Or clogged injectors? Try a bottle of fuel injector cleaner????? |
(Post 43142)
The IACV is idle air control valve. Usually attached to the throttle body.
Does your engine runs on diesel? Could be low fuel pressure? Or clogged injectors? Try a bottle of fuel injector cleaner????? I have used injector cleaner before, also took them out, cleaned THOROUGHLY and replaced back. No change. I am leaning towards faulty/worn out fuel pump as well. |
