-   CR-V Forum (https://hondaforum.com/forum/cr-v-forum-13/)
-   -   2007 CRV Foglights -- Need Help (https://hondaforum.com/forum/cr-v-forum-13/2007-crv-foglights-need-help-2331/)
dlprince Mar 2, 2008 11:01 PM
I have a 2007 CRV, I bought the factory foglights and installed them easily. They worked for about 6 months and stopped. I replaced both bulbs...nothing. Rechecked every connection, wire, socket, etc. It dash shows the lights working, also showsI am getting power to the sockets.
I took it to honda to get it looked at, they were no help and wanted $75/hour.
RecentlyI replaced the relay and they worked!!! Later that dayI turned them on again and they were not working...again.
Any advice or reasons why this would happen?
Anything will be helpful.
Thanks
superg Aug 27, 2008 02:47 PM
RE: 2007 CRV Foglights Need Help
I would split the relay so you use one per side and check the amps rating.
If they blow again check the voltage to the relays with the engine running, you may need to use an inline ohms resistor.
SG
