2010 CRV Headlight assembly replacement
Old Apr 22, 2024 | 04:01 AM
Scott in FL's Avatar
Default 2010 CRV Headlight assembly replacement
After years of restoring my 2010 CRV's (LX) headlights, I would like to replace the entire assembly and start over with new, clear lenses. I've found several YouTube vides and it doesn't look too time consuming. Has anyone done this, and is it do-able in an afternoon? Thanks.
Old Apr 22, 2024 | 01:35 PM
Operation CHARM: Car repair manuals for everyone.
Home >> Honda Truck >> 2010 >> CR-V 2WD L4-2.4L >> Repair and Diagnosis >> Lighting and Horns >> Headlamp >> Service and Repair
Headlamp: Service and Repair
Headlight Replacement
1. Remove the front bumper Front Bumper and the front fender trim .
2. Remove the connectors (A) from the headlight assembly (B).
3. Remove the harness clips, screw, clip, and three bolts, then remove the headlight assembly with the corner upper beam (C).
4. Remove the bolt (D) and the corner upper beam from the headlight.
5. Install the headlight in the reverse order of removal.
6. After replacement, adjust the headlight.
pro multis · About Operation CHARM
Old Apr 22, 2024 | 03:56 PM
Thanks. It's removing that front bumper and trim that worries me. I bought the tool, but always seem to mess up those clips!
Old Apr 23, 2024 | 08:54 PM
I did that replacement for my nephew's 2007 CRV LX AWD. Yes the bumper comes off to access the couple of bolt that hold the head light assembly to the body of the car. It isn't hard and it was done in two hours since we did not know how to do this. Trim tools to take out the exterior body trim panels. Drill to handle the bolts or screws. Just take your time and everything will be fine. Check Youtube for videos. It helps to see what else is needed to be done.
Old Apr 24, 2024 | 03:35 AM
Thanks. This is very helpful. I've watched a couple of really good videos, and have the trim removal tools from a previous repair, so I'll go for it. Thanks again!
Marcus Smith
Oct 16, 2019 02:44 PM
tpwhite818
Nov 12, 2010 03:55 PM
trev0006
Jan 3, 2009 02:40 PM
amy
Nov 27, 2007 11:29 AM
