2013 CRV - Left volume keypad on steering wheel not working
Just the left hand volume keypad is not working. I had oil warning come on and now I can't shut it off (even after changing oil) because I can't get into the menu. I just tried replacing the keypad and harness and still not working. The right side keypad and airbag are working (airbag warning light not on) so I assumed the problem was just with the left keypad. Is there a fuse for just the left volume keypad and if so, which one is it? Any other suggestions on how to fix the keypad and/or reset the oil warning so it's not flashing at me with the wrench icon?
Sometimes the HDS (Honda's specialized scanner) can reset the maintenance minder.
It could be the clock spring in the steering column
But would need to test before doing such a replacement
It takes a ling time to do the clock spring. (labor)
