2013 CRV Wet Carpet
3 Attachment(s)
The DS floor of my 2013 CRV is getting wet. I eliminated the sun roof drains as the issue. When pulling back the carpet, I found that water was laying in the floor pan and being wicked up through the padding to the carpet. I also found a bracket on the floor under the center console that was rusty, with a rust trail where the water is running (pics attached). Any ideas of the source of the water?
Welcome in,the first thing that comes to mind is the drain for the A/C is stopped up but that looks like a leak from the fresh air intake in front of the windshield.what I would do while you have the carpet pulled back is get under the dash with a flash light and have some run waterdiwn the outside of the windshield and see if you can spot the leak.good luck.
