2020 CRV - Car won’t start after changing battery
Old Aug 21, 2023 | 09:09 PM
Bo K's Avatar
Default 2020 CRV - Car won’t start after changing battery
I tested the battery and it has 12 volts and I tested the fuse box and it has power but there is no power in the cabin and a white light flashes around the starter button when pressed. Other than that there is no indication the car has power. I’m stumped.
Old Aug 22, 2023 | 12:30 PM
Make sure the battery is hooked up correctly. Then, check cable from battery to fuse box.
Then, check the large fuses.
Old Aug 22, 2023 | 08:45 PM
You need a battery.. 12 volts is a bad battery .
Old Aug 22, 2023 | 09:42 PM
Bubbalou88's Avatar
How do you figure that? 12 volts is the resting voltage of a battery when not being charged by the alternator. The Alternator should put out 13.5- 14 volts when the engine is running. It takes higher voltage to charge a battery but not too high so you do not boil the water out of it.
The only time a 12 volt battery is deemed bad is if the voltage drops significantly (7-10 vdc) when the starter engages,
Old Aug 22, 2023 | 10:22 PM
12 volts ix to low. Should be 12.6 at rest.
Old Aug 23, 2023 | 11:48 AM
Bubbalou88's Avatar
That depends. It will be 12.6 vdc right after you turn the car off but can drop after a bit. 12 volts should still start a vehicle.
Old Aug 23, 2023 | 12:56 PM
Good luck. You'll need it. In the end you'll get a battery and we will never hear from you again.
I'm done here.
Old Aug 23, 2023 | 11:03 PM
This comes from a search on the internet about the state of charge of a car battery.
Notice that 12 volts is not a good state of charge.
Just something to consider.
https://www.google.com/search?q=stat...hrome&ie=UTF-8
Further down the page
What is a good state of charge for a car battery?
A fully charged 12-volt car battery (standard voltage) will read between 12.4 and 12.7 volts. Pro tip: Anything below 12 volts is low, and there's a good chance your car won't start.
Old Aug 24, 2023 | 10:36 AM
Bubbalou88's Avatar
Thank you for your input here
Old Aug 24, 2023 | 12:56 PM
  #10
Bo K's Avatar
Default Thanks all!
It turned out to be the fuse in the picture below. I replaced it and everything is now back to normal.
