2021 CR-V Transmission Fluid
Old Feb 25, 2025 | 02:43 PM
Slk1024's Avatar
Default 2021 CR-V Transmission Fluid
Hello,
What is the maintenance schedule for transmission changes for a 2021 Honda CR-V?
Thanks
Old Feb 25, 2025 | 05:46 PM
Bubbalou88's Avatar
From Google:
“For a 2021 vehicle, the recommended transmission fluid change interval is typically between 30,000 and 100,000 miles depending on the specific car model and driving conditions, but always consult your owner's manual for the most accurate information as some newer vehicles may have "lifetime" transmission fluid which technically doesn't need changing, though regular checks are still advised.
Old Feb 26, 2025 | 09:43 AM
Just Ducky's Avatar
Default Reality
Honda uses their own computer algorithm called Maintenance Minder.
You did not specify which trim you have so you get a generic answer:
Use the maintenance minder.
Had you included pertinent details there are folks here that can offer some suggestions to help you make your transmission last.
or to answer your question as written: Honda does not recommend changing the transmission.
MPeffer
Mar 28, 2023 04:49 PM
don9902
Oct 2, 2022 05:54 AM
Randy Gibson
Aug 4, 2022 11:20 AM
Alp
Nov 8, 2021 09:08 PM
444samc
Dec 1, 2019 07:11 PM
