2022 crv infotainment
Old Jan 26, 2024 | 07:35 PM
sbcrv's Avatar
Default 2022 crv infotainment
When I used to start my car the main menu would pop up and allow me to select smartphone connection / setting ETC. Now when I start my CRV the home menu appears for a moment and then it opens “info menu” with things like Trip computer / voice info and then trip computer stays on the screen. How do I disable this. I want main menu to show audio setting info phone etc.
Old Jan 26, 2024 | 08:36 PM
Just Ducky's Avatar
Default Which Switch
You did not specify which system you have (my ‘22 CRV has Display Audio)
sooo, turn to page 251 in your hymnal to begin the search. You are likely looking for the “Remember Last Screen” selector.
Mine is found at Home ~ Settings ~ System ~ Others
Old Jan 26, 2024 | 09:43 PM
sbcrv's Avatar
I have an 2022 exl gas version. Not sure what you mean?
Old Jan 26, 2024 | 11:18 PM
sbcrv's Avatar
Mine has the same as you do.
Old Jan 27, 2024 | 08:48 AM
Just Ducky's Avatar
Default Narrowing
Good news. Your display audio begins on pg 272. The flow chart is on pg 369.
If you followed the flow path I already gave you and it did not correct the problem that would indicate a customized menu was selected. That would need to be reset to default to get your home screen back. pg 388
If all else fails you could try the nuclear option and reboot the system. pg 394
Hope this helps …
don9902
Oct 2, 2022 05:54 AM
Podenco
Feb 21, 2022 01:07 PM
geno368
Jul 17, 2021 12:24 PM
kraven
Mar 10, 2009 07:52 PM
mcqueen
Jan 22, 2008 04:51 AM
