2017 CR-V EX-L Engine Splash Shield
Old 04-02-2018, 01:45 PM
skid2964's Avatar
Default 2017 CR-V EX-L Engine Splash Shield
I guess the plate covering the bottom of my engine is called the "Engine Splash Shield". The plate you have to remove to access the engine to change the oil. It has several quarter turn fasteners and three screw in fasteners.
Some of my fasteners have fallen out, where can find these for purchase?
Old 04-07-2018, 11:12 AM
Advance auto parts has a section called HELP, you may be able to find them there,or if you have a company called Fastenall ,they carry a lot of fasteners no one else does,good luck.
Old 05-03-2018, 12:10 PM
rutledj's Avatar
Did you have any luck finding these? I am missing some of the metal screw in ones as well.
Old 06-17-2018, 01:47 AM
BMCRV's Avatar
Do you guys also have a big gaping hole at the back of the engine? I have not come across this in any car I have owned over the past 35 years, I can see the ground standing in front of the car and looking at the rear of the engine, did the factory forget to install a heat shield of some sorts?
myhonda
06-05-2019 03:13 PM
Larry Mich
05-17-2018 05:43 PM
StephenLep
12-14-2017 12:15 PM
jdinDC
08-11-2017 08:59 PM
akdanak
07-13-2017 12:31 PM
Quick Reply: 2017 CR-V EX-L Engine Splash Shield
