Auto Trans Oil Change
A 2009 CRV 4WD- I tow behind a Motorhome-
The book says change the Transmission fluid every 2 years- seems reasonable- Is the drain plug the 3/8 square drive female plug ? I understand it holds 3 1/2 quarts? Honda only fluid- no synthetics allowed? Anyone have experience with this issue? Thanks in advance Mark |
yes on the female plug
honda only fluid |
Thanks- Honda Fluid it is-
Mark |
Hey that's a nice details you have shared with us.Thanks for posting here.
I have mine fulshed every two years,85,000 miles with out a problem.
More auto trans. fluid change
I'd like to also ask if the '09 CRV auto trans uses a tranny filter inside the pan. If so, I'll need to get myself a new trans. pan gasket. I'll go out on a limb with this one. About a year or so ago, I was looking for some info. on changing my radio and some kind soul in this forum went to the trouble of sending me a detailed procedure, complete with illustrations, which looked as if they came out of the Honda service manual. Are you still out there ? I could use another response like this for the auto trans. fluid change.
Thanks in advance for all responders. |
That was probably acmech,he is our Mod here,he will most likly answer your request if it were him.I may be wrong about this but there should be a drain hole and refill hole on the side of the trans. the top is the fill hole and can be taken out with a 17mm wrench the lower hole can be taken out with a 3/8 ratchet. I would replace the gaskets on the plugs . Just drain and refill.
http://www.ehow.com/how_4583596_chan...uid-honda.html
found on ehow.com how to change the tranmission fluid cr-v there are a couple but this one tells you the plug is at the most bottom of the transmission and how to change the fluid. |
Thanks acmech and bucwheat for the very helpful responses. Gonna hopefully do it next weekend.
