Brake issue
Old Mar 2, 2020 | 04:38 AM
Faizal Ahamed's Avatar
Question Brake issue
Dear All
i own Honda crv 2007 AWD. i have problem when applying brake pedal even on slow speed it vibrates or jumps like working ABS. my brake disc in good condition and i replaced pads recently. kindly advice what will be the exact problem.thanks
Old Mar 2, 2020 | 05:54 PM
When did this issue occur?
After you replaced the brake pads?
Have you raised the front wheel and put hands at 3 and 9 or 12 and 6 to see if there is play in the wheel
Ball joints or tie rod ends have any play??
Inspect the tone ring on the CV axle to see if it is broken or missing any teeth??
Do any warning lights come on?
Old Mar 3, 2020 | 02:43 AM
You may be rite. I have modified and there is a variation in tyre size. Front is bigger and rear smaller. After my replacement of pads it was fine. Warning lights are some time shown brake lights and abs lights.
Old Mar 3, 2020 | 09:29 AM
Different size tires could cause issues with the ABS system.
Front tires and rear tires are rotating out of sync
This could cause ABS to activate
Don't know for sure.
Old Mar 3, 2020 | 11:58 PM
As i am facing this problem since i modified the tyres , i will change in to original size and update you the feed back. Thank you
jastrong
Aug 28, 2019 01:35 PM
Barletter
Jul 3, 2014 12:47 PM
Sacha Mazloom
Apr 21, 2014 11:04 AM
rstaggs01
Dec 12, 2011 09:14 AM
spidey3479
Nov 19, 2006 02:27 PM
