Brake light issues
Recently bought a '98 CR-V. Everything is in tip top shape but the brake lights don't work. Replaced brake pedal switch and bulbs to start with and no change. Tonight I broke out the multi-meter and checked for power at the driver side taillight connector. There's power in turn signals, running taillights but nothing from brake pedal when engaged. I'm pretty clueless what it could be at this point. Any suggestions?
welcome to the forum. check the emergency switch, i believe the brake power goes thru that. also check the fuse.
Originally Posted by avisitor
(Post 37489)
Download the service manual at Archive.org
https://archive.org/details/HondaCRV19972000 |
Originally Posted by acmech52
(Post 37485)
thanks for the help. turns out the manual was the best tool in diagnosing the problem. missed a fuse(15A) in the under hood fuse block cheers!
Originally Posted by AlpineBud
(Post 37519)
