Car Won't Go Into Gear
Old Jan 29, 2024 | 03:26 PM
catbelly's Avatar
Default Car Won't Go Into Gear
So I was having a problem getting car into gear, if I pumped the clutch it would go, so I assumed Master or Slave cylinder.
I ended up replacing both. I then adjusted clutch pedal and bled system (going through like 2 quarts of brake fluid). The clutch "feels" great - it has good pressure, returns good, etc... but it will not go into gear still. The internet says this is usually a symptom of bleeding but when bleeding I'm really not seeing any bubbles come out anymore. Now even when pumping I can't get into gear (I can change gears fine if car is off). Is there anything else I should look for?
Old Jan 29, 2024 | 09:48 PM
We use a pressure bleeder and as it's pushing fluid through we tap on the MC and the line going to the slave. This gets out micro bubbles.
Old Jan 31, 2024 | 06:39 AM
catbelly's Avatar
Thank you for the reply! The issue did end up being more bleeding - I basically tried every combination of bleeding techniques, tapping the cylinders and lines, vacuum bleeding, pumping pedal fast etc... so something finally worked.
Old Jan 31, 2024 | 10:25 AM
That's what it takes sometimes. Glad you got it.
Smokeless
Jun 26, 2019 03:30 PM
00civicGSR
Feb 17, 2013 09:41 AM
95civicdx
Dec 21, 2011 12:00 PM
95civicdx
Dec 7, 2011 08:23 AM
herecometheazn
Sep 7, 2007 02:13 AM
