CAT Placement - O2 code
Old Apr 5, 2022 | 09:45 PM
Revvy's Avatar
Default CAT Placement - O2 code
Hello. have a question about my 2005 CRV LX.
My catalytic converter was stolen a few months ago and I got my local mechanic to weld on a universal with two new O2 sensors for me. It keeps throwing a bad O2 sensor code, so I crawled under to take a look and noticed two things. First, the welds leak (great big bubbles when I spray em’) Second, the cat is noticeably closer to the engine than it was.
I know exhaust leaks can cause an O2 sensor code. Does the location of the CAT cause a problem? I know closer is better, but perhaps moving it a foot upstream is causing something the be unbalanced? Trying to make sure I know what to talk with the mechanic about when I take it back in.
Old Apr 6, 2022 | 01:19 AM
Aftermarket universal replacements .... Thumbs down ... bad weld ... both thumbs down
Money already spent.
Option 1, have the weld done again and hope it is done right and/or see if new O2 sensor will fix it??
Option 2, spend lots of additional money to get correct parts and hope that will fix it??
Honda vehicles do not like after market electronics. ABS sensors, O2 sensors, etc.
I wish you luck
I am still fight a low efficiency cat code.
Old Apr 6, 2022 | 05:53 AM
Revvy's Avatar
I wish you luck
I hear ya. Honda parts would have been more than the value of the vehicle, so I had to try aftermarket.
do you think the location of the CAT would be a problem? It’s about a foot closer to the engine than it was.
Old Apr 6, 2022 | 10:00 PM
Make that guy weld it up correctly or he has wasted your money.
Old Apr 7, 2022 | 12:52 AM
It should not make any difference cause it is still the same exhaust gas. It does not change much in that extra foot.
Chrischuck73
Mar 26, 2022 12:29 AM
Demmerm
Apr 11, 2021 09:15 AM
danmurphymn
Jan 8, 2021 10:50 PM
scanner737
Nov 10, 2017 12:56 PM
Ben
Apr 3, 2007 04:44 AM
