CR-V hibrid touring 2023 -
Old Dec 27, 2025 | 11:38 AM
Sabuhi's Avatar
Default CR-V hibrid touring 2023 -
Merhaba, 2023 model bir Honda CRV Hybrid Touring aldım. 20.000 km kullandım. Bazen sürüş sırasında araç sarsılıyor, gaz pedalı boşalıyor, gaz kademeli olarak kesiliyor ve araç duruyor. Bu sırada birçok uyarı ışığı yanıyor. Aracı kapatıp tekrar açtıktan sonra sorun çözülüyor.
Old Dec 27, 2025 | 01:17 PM
Just Ducky's Avatar
Default Shake, Rattle & Roll
Hi There,
It appears that you are having a problem with your internal combustion engine. The check engine light indicates that there is a fault with emissions that is shutting the power off.
You need to scan for DTC’s (diagnostic trouble codes). The usual issue that causes that is either a bad head gasket or injector malfunction.
You need to get it in a repair shop ASAP to avoid major failure.
Meanwhile, monitor your coolant level, check your oil level and the possibility of fuel or coolant in your oil.
Güle güle
Tim Heally
May 9, 2024 07:52 AM
Fooshe
Mar 1, 2024 10:46 AM
M T
Jan 1, 2023 07:36 PM
achalshahbhavans
Oct 23, 2021 01:21 PM
Janeen
Aug 30, 2016 11:23 PM
