-   CR-V Forum (https://hondaforum.com/forum/cr-v-forum-13/)
-   -   Crank no start 2010 CRV (https://hondaforum.com/forum/cr-v-forum-13/crank-no-start-2010-crv-16393/)
HondaTim Dec 20, 2022 09:51 PM
I brought my CRV into the garage for an oil change. I finished that on Saturday, and Monday morning it wouldn’t start. It cranks, sputters but no start. I tested the PGMFI relay, it was good. I can hear the fuel pump priming, and after cranking I can smell gas (a bit). The fuel pump relay is working as well - I didn’t pull it and test it but felt it click when I turned on the ignition. I also tested voltage on a fuel injector and found 9v on one side and 2v on the other.
im kind of at wits end and would really love suggestions on where to go from here. Thanks!
grcauto Dec 21, 2022 10:26 AM
Have you tried ether? Fuel pressure?
HondaTim Dec 21, 2022 12:07 PM
Niether - will try. Thanks.
