Disabling HondaLink radio
Old Aug 15, 2023 | 10:30 PM
Coby's Avatar
Default Disabling HondaLink radio
I'm contemplating getting a Gen5 or Gen6 CR-V, and I would prefer to have a "disconnected car". Have any of you successfully removed or disabled the cellular/LTE radio in your CR-V? Any pointers to instructions or reports?
Old Aug 16, 2023 | 08:53 AM
Pull the fuse?
Old Aug 17, 2023 | 03:40 PM
Coby's Avatar
Pull the fuse?
Per a local dealer, the radio is embedded in the PCM, so pulling a fuse could prove problematic. (I'm not sure I fully believe that answer, but it's the one I've gotten.)
Old Aug 17, 2023 | 03:51 PM
Your radio is a modular unit and is not a part of the PCM. But, What portion of the unit are you trying to delete? GPS? Cellular only? I think I misunderstood your question. I do know that to delete any portion and not all will require removing or disabling an IC chip from the unit.
I wouldn't know what chip does what without a service manual for the unit.
I would get hold of a module rebuilder and ask them if they can delete whatever it is you need.
I would think any place that repairs these can do what you need.
Old Aug 18, 2023 | 07:27 AM
Coby's Avatar
Your radio is a modular unit and is not a part of the PCM. But, What portion of the unit are you trying to delete? GPS? Cellular only? I think I misunderstood your question. ....
I'm trying to disable or remove only the cellular radio, although I'm willing to lose GPS as collateral damage. I want to keep Bluetooth working as well as regular FM radio reception.
Old Mar 19, 2024 | 07:20 PM
nes1984's Avatar
Did you ever find a solution?
Old Mar 19, 2024 | 07:23 PM
Coby's Avatar
Sadly, no. I ended up buying a different make and model.
Old Mar 19, 2024 | 07:41 PM
nes1984's Avatar
Can I ask what you ended up with? The only brand k have found where I could disable everything is Ford so far.
Old Apr 7, 2024 | 12:44 PM
Coby's Avatar
A Subaru Outback. Some years and trim levels are available without the telematics module, and there are (clunky) ways to disable it in the ones that have it. Also, most of the cars (in the years I was looking at) shipped with only 3G network support. As 3G networks have been turned off, that's made those cars "semi-disconnected".
R89074
Feb 1, 2020 06:52 PM
billy421
May 20, 2019 09:06 PM
Kelly1266
Mar 24, 2018 02:27 PM
Mam59
Oct 7, 2016 08:45 PM
wahinekehau
Jan 26, 2007 10:29 PM
