-   CR-V Forum (https://hondaforum.com/forum/cr-v-forum-13/)
-   -   Disabling HondaLink radio (https://hondaforum.com/forum/cr-v-forum-13/disabling-hondalink-radio-16818/)
Coby Aug 15, 2023 10:30 PM
I'm contemplating getting a Gen5 or Gen6 CR-V, and I would prefer to have a "disconnected car". Have any of you successfully removed or disabled the cellular/LTE radio in your CR-V? Any pointers to instructions or reports?
grcauto Aug 16, 2023 08:53 AM
Pull the fuse?
Coby Aug 17, 2023 03:40 PM
Originally Posted by grcauto (Post 42690)
Pull the fuse?
Per a local dealer, the radio is embedded in the PCM, so pulling a fuse could prove problematic. (I'm not sure I fully believe that answer, but it's the one I've gotten.)
grcauto Aug 17, 2023 03:51 PM
Your radio is a modular unit and is not a part of the PCM. But, What portion of the unit are you trying to delete? GPS? Cellular only? I think I misunderstood your question. I do know that to delete any portion and not all will require removing or disabling an IC chip from the unit.
I wouldn't know what chip does what without a service manual for the unit.
I would get hold of a module rebuilder and ask them if they can delete whatever it is you need.
I would think any place that repairs these can do what you need.
Coby Aug 18, 2023 07:27 AM
Originally Posted by grcauto (Post 42716)
Your radio is a modular unit and is not a part of the PCM. But, What portion of the unit are you trying to delete? GPS? Cellular only? I think I misunderstood your question. ....
I'm trying to disable or remove only the cellular radio, although I'm willing to lose GPS as collateral damage. I want to keep Bluetooth working as well as regular FM radio reception.
nes1984 Mar 19, 2024 07:20 PM
Did you ever find a solution?
Coby Mar 19, 2024 07:23 PM
Sadly, no. I ended up buying a different make and model.
nes1984 Mar 19, 2024 07:41 PM
Can I ask what you ended up with? The only brand k have found where I could disable everything is Ford so far.
Coby Apr 7, 2024 12:44 PM
A Subaru Outback. Some years and trim levels are available without the telematics module, and there are (clunky) ways to disable it in the ones that have it. Also, most of the cars (in the years I was looking at) shipped with only 3G network support. As 3G networks have been turned off, that's made those cars "semi-disconnected".
