Door lock issue
Old Dec 29, 2016 | 10:14 PM
theleeb's Avatar
Default Door lock issue
Folks - I have two door lock issues on my 2008 LX...
1. Passenger side power door lock button/switch does not engage the locking mechanism. Yes, I can operate the passenger side lock from the button/switch on the driver's side panel.
So the door lock will lock and unlock but just not from the passenger side.
Do you think it's just a switch problem? If so, I am hoping that is something I can replace without taking to shop.
2. The driver's side door lock will not unlock when using a key. No idea what that is all about.
Any help is greatly appreciated!
Thanks.
Old Dec 30, 2016 | 03:38 AM
welcome to the forum. 1. do check the switch first, then the solenoid that actuates the lock. 2. need to check to see if the clip has fallen off the inside of the door panel.
Old Jan 6, 2017 | 07:02 PM
Also you might check to see if a lead has worked its way loose from the switch,that happened to me years ago.
Old Jan 7, 2017 | 06:15 PM
theleeb's Avatar
Thanks guys....I'll take a look. Sounds like it might not be a major issue.
Old Jun 18, 2020 | 12:49 AM
jacslater's Avatar
Had the same problem. Did everything to my knowledge to try and fix it but didn't work. I had this locksmith to take a look at it and he fixed it pretty well.
Old Jun 18, 2020 | 10:15 AM
What did he do?
Old Jul 18, 2022 | 09:07 AM
Jmullan99's Avatar
I fixed the issue and got another.
First, replacing the master switch panel cured the front passenger window. Rear passenger replaced the actuator fixed it.
Now, the drivers window always has power. Even after retained power limit has passed. Causes me concern because if I leave the window open a crack someone can put a stick in and lower the window.
Could this be a problem with the function of the new master switch panel?
nazz
Feb 28, 2009 12:57 PM
wannabedivin
Jan 20, 2009 02:57 AM
inewton55
Nov 25, 2008 10:00 PM
Imaprincess
Sep 13, 2006 02:48 PM
cdagza
May 3, 2006 09:48 PM
