frustrated just a little
Good day, so I had this squeaky noise coming from my front left side wheel. Figured it was either bearings or brakes. Well as I pulled into my driveway I hear a creak and grind. Long story short I changed my tie rod inner and outer, bearing,hub, brakes and lower balljoint. Took it for a test drive and still have the damn noise and creaking! Besides the strut what else could it be... No stupid answers, at this point I'm reading everything I can in regards to the problem even if it sounds restarted! Thanks in advance
Maybe you can share the MY and trim incl. drive configuration as it may make a difference.
Shot in the dark. Sounds like you did not check the CV joints.
Disregard the 1st paragraph. I just read in another post you made that “I have a 2008 AWD and have 348k…” Speaking of that post, you responded to a SEVEN YEAR OLD post where the OP has not been back since that post.
