High Fuel Consumption - CRV 2006
Greeting
Just bought a 2nd hand 2006 CRV. Did abt 330km for one full tank. Is this the normal milege? Any suggestions to improve the fuel consumption? Thanks. Cheers Andrew |
Welcome in,whats's that in miles?
welcome to the forum. 330km = 205.05 miles. 1km=0.062137119. but gallons used unknown. still hard to determine, but appears to be poor milage, depending on how the vehicle is driven.
Guys
Thanks for the reply. My last full tank was 50 liters/ 13.2 gallons and clocked abt 330km. Any suggestion as to how i may be able to improve the fuel consumption? Cheers Andrew |
basic maintenance like plugs,air filter,oil you can use 0w20 in a 2006 that would give better mpg. also change out your primary oxygen sensor those get dirty and give bad gas mileage. maybe add some fuel system cleaner i recommend AMSOIL if you can find it. check tire pressure run it on the higher side.
