High mileage, dying transmission 2008: let it go?
I have a 2008 EX-L with ~256K miles on it. Still driving reasonably well other than an occasional shaking/stutter it's had for many thousands of miles. Been told the transmission has metal (probably more than just shavings I imagine) in the fluid though and needs to be replaced or will die at some time, though who knows when. Also need ~$1400 in front suspension work (struts/sway bar links). All told looking at ~$3500 for just the most basic fixes of putting in a used transmission (with 130K miles on it already) and doing the suspension work.
KBB of car is anywhere from $2800-6000 according to calculators, though possibly less than that. But would basically have to spend $30k+ to get any sort of good slightly used or brand new CR-V in my local market. Can afford that if needed but looking for opinions - should I invest in keeping the old one rolling or at this point cut my losses and invest that as 10% of a new one? I have no familiarity with transmission failure and replacement so just trying to get a handle on whether it is a poor return on investment at this point. Only reason I'm even considering is because both used and new cars are so wildly inflated right now. |
I don't know your financial situation but the decision is yours. I can't tell you because I don't know you or your circumstances. Ask your friends. They will be better able to advise you.
welcome to the forum. i am not a wealthy person, usually broke. my opinion would be to do some research into a good used low milage transmission from a salvage yard, or ebay salvage yards, or google site that has your type and make trans. find a good reputable shop that is willing to change the trans for a fair amount $ 3 to 600.00. most ebay or reputable salvage yards will give you a 90 day warranty. your 235k engine when cared for well will make 400k+ the cheapest car is the one paid for. a newer ride is more expensive than to repair what has been paid off. again my opinion.
Now is not the time to buy a used/new car.
Originally Posted by Finch Platte
(Post 39668)
Used/new cars are pretty sparse on the lots around here. Don't know if this has transferred to the private markets or not. If so, I imagine there're a lot of shady cars out there.
Sometimes the devil you know is better than the one you don't.
If you're still around, I'm curious about which route you took. |
