-   CR-V Forum (https://hondaforum.com/forum/cr-v-forum-13/)
-   -   How do you change tag light on 2007 CRV? (https://hondaforum.com/forum/cr-v-forum-13/how-do-you-change-tag-light-2007-crv-6951/)
vashti_21901 Jan 19, 2011 11:04 AM
Would appreciate anybody sending me how to change a tag light bulb on a Honda 2007 CRV. I checked owner's manual and doesn't have info on how to change.
bucwheat Jan 25, 2011 09:27 AM
See if this helps ,Look up at the light lens - remove the two screws and pull off the lens. Rotate the bulb socket 1/8 turn counter-clockwise and detach it from the lens housing. Pull the bulb straight out of the socket and replace. Replacement is the reverse of removal.
vashti_21901 Feb 1, 2011 12:43 PM
Thanks!
It worked! Thanks again :)
bucwheat Feb 2, 2011 12:36 PM
Glad we could help sir! :D
