key noise
Hi all. I am new to this forum. I have a few questions. When i tried to start my crv i heard a buzzing noise in the start mode. This buzzing sound comes from the key area I believe. I tried starting it around ten times and always the car started. But when you go to start the car and dont fully start the car you hear a buzz. This buzz almost sounds like a key reminder. Any ideas? the Honda is a 2004 Honda CRV.
Thanks
Jerryt
Thanks
Jerryt
I just googled noise from key on 2004 honda crv. And guess what a video showed the exact buzzing noise. It was the ignition switch in the column. Has anyone ever replaced this ignition switch? any insight would be appreciated.
thanks
jerryt
thanks
jerryt
It is a very difficult procedure,if I remember right the mounting bolts from the factory are sheared off and very hard to get off,as well as having to rekey the new cylinder and dealing with radio codes because of disconnecting the power,that's just some of the headaches.its best to let a pro do it.
Well a lot of times you have to take you tube videos with a grain of salt. So when I saw this video work I thought why not. The switch is in the steering column. There are three screws you need to remove and separate the two halves. the switch is opposite the key side. The switch is held in by two screws. Also there is a clip that plugs in. To reassemble it is in the reverse order. After trying to start the car about twenty times the buzz was gone. I assume if I didnt replace this switch the car would eventually not start.
Thanks
Jerryt
Thanks
Jerryt
