Locks lock right after unlocking
I currently have 2 doors (both passenger side) that relock almost immediately after unlocking. Both remote and by door switch.
For a while only the rear passenger lock did this. Now the front is also doing it. Any thoughts on the "usual suspects) before I pull door pa els off? TIA |
welcome to the forum. possible master control on the drivers door.
Thanks. Is there a test to check it?
You can back probe the connector for the lock actuator to determine if it is getting a signal to lock after being unlocked
Would help to have schematics to door locks Google free service manuals for Honda CRV I used this one for my 2007 https://www.workshopservicemanual.co...honda-crv.html I have had issue with lock unlocking after locking either with remote or door switch. Turned out to be the actuator. Replaced with internet special. |
I ordered the right front and right rear actuators, and the main control panel (drivers). I will try the main first when it arrives. If fixed, great. If not, I will try the doors. Ordered from Amazon so should be easy returns. 👍
