no check transmission fluid level dip stick
So why is there no check transmission fluid level dip stick for my 2016 CRV EX with AWD.? It only has a transmission fluid fill port plug that has HCF-2 on it with no check level dip stick any where else in the engine area.
Originally Posted by jim4b
(Post 41926)
Not sure where they are on your tranny but there will be a plug you remove to check. |
welcome to the forum. As grcauto states it is a plug just above the drain plug. https://www.crvownersclub.com/attach...0-jpeg.156965/
Okay thanks, and now I know.
Also for my 2016 CRV CVT transmission shift lever inside the vehicle moves too stiff, and so can it be lubed or adjusted to allow it to shift easier and with less force needed.?
