Random alarm which won't stop
Old Jan 4, 2019 | 12:32 PM
Jos1ization's Avatar
Question Random alarm which won't stop
Hallo everyone. I'm having a problem with the alarm on my 2005 Honda CRV and am hoping someone can help or at least shed some light on what's going on.
I've had her for 5 years now and she's never given me any problems. I'm not sure if it's related or just an uncanny coincidence, but since I had a dash-cam fitted about 3 weeks ago (hard-wired into the fuse-box underneath the steering column) the alarm has been going off randomly. I can rarely stop it. I lock and unlock the car, start the engine and even drive along the road, but the siren won't stop.
I’ve had a new battery put in the key-fob and the car battery itself checked (it’s at 70%) The alternator is also fine. I ‘have’ noticed recently that there’s a red light on the instrument cluster RHS (immobilizer?) which flashes when I arm the vehicle which I haven’t noticed before (and doesn't happen all the time)
For the last few days, I’ve disconnected the dash-cam each time I leave the car/arm it, and 9 times out of 10 the siren doesn’t go off, so I thought this was the solution. However, the siren started going off tonight when the car was just parked in the driveway and no cam attached. Ps. None of the lights flash when this happens – only once when I drove the car down the road did the hazard's go nuts.
My mechanic has had it on the ramp but is at a loss! If anyone can give any suggestions it would be much appreciated! Thank you : /
Old Jan 4, 2019 | 02:24 PM
Lochinvar's Avatar
Weird things can happen when you add electrical accessories. I would suggest starting by restoring all the electrical stuff to original specs, and make sure the problem goes away. Then add your cam to a circuit that is not connected to your computer, immobilizer, or alarm.
Old Feb 16, 2019 | 05:17 AM
Thanks Lochinvar. She's been to the Honda garage three times now and all they keep saying is the battery in my siren is probably on it's way out. I've told them I'm not convinced and that the problem is relating to the alarm itself. But they seem fixated on this.
When I'm driving along, the immobilizer light will sometimes start flashing on the instrument cluster and then all hell breaks loose (hazards etc. like she thinks she's being stolen) If I stop the car, turn the engine off, and arm/disarm her, everything returns to normal for a while. I've since let Honda disconnect the siren and guess what? It STILL happens so it isn't the siren at all. This also puts me in an awkward position with my insurance company as I'll have to let them know.
I took your comments on board about having the dash cam removed altogether (as mentioned in my initial post, this problem started the day after it was fitted) but I worry the damage has already been done. If I disconnect the cam entirely i.e. unplug it from the fuse box, the problem persists but not as regularly. I think the alarm itself has been upset. Is there such a thing as a re-set that the mechanic can do?? Please advise because if Honda can't even figure it out, I'm lost.
Old Feb 16, 2019 | 09:28 AM
I would still remove the dash cam completely for awhile and see what happens.
acporter15
Mar 18, 2018 03:49 PM
Jante Andrews
Jun 2, 2017 07:25 PM
reyjustin
Nov 19, 2010 12:10 PM
Kresh
May 28, 2006 12:18 AM
Kresh
May 2, 2006 11:11 AM
