Starting issue
I have a 2013 Crv. In the past couple of months I've had a starting issue. You have to crank it for at least 15 seconds
before it starts. It has only happened a couple of times, any thoughts. Tks |
welcome to t he forum. if you carry a bunch of keys with your vehicle key, it might be the key ignition being worn out.
starting issue
I should have been a little more specific. It cranks and it is not getting fuel. Its like turning over a motor with a carb and having to pump it to get it going.
This being fuel injection I don't think you want to be doing that. Might be a fuel pump issue. Tks |
Not to be rude or anything like that, ...
Only you know what is going on, as we are not there is see or hear what is going on. You say fuel pump then we believe you. However, I like to ask what makes you believe that? What tests were done? The symptoms are long crank time. Possible causes, ... Could it be the fuel pressure regulator? Clogged fuel sock on the fuel pump? Could it be a sticky fuel injector(s)? Or intermittent crank sensor? Can it be the battery voltage (at the ECM) drops below 9 volts while cranking? |
