Timing chain
I have a 2003 Honda CRV. How can I tell if the timing chain has skipped a tooth? Simptoms are engine light goes on and sometimes blinks Doesn't start sometimes after sitting awhile.I've replaced the fuel pump,injectors,plugs and rotors
welcome to the forum. timing chain jump runs bad to not run. does not matter hot or cold. possible bent valves, normally engine stops running.
When it doesn't want to start, (crank, no start) check for
Fuel Air Spark Timing Exhaust Compression |
There you go, back to basics. I'm saving that response, thanks!
